I have installed a new cartridge in my Samsung SF 370 but it still displays "install new cartridge"
SOURCE: Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
SOURCE: Everytime I send a fax from my samsung sf 370 i get
It can be the other person's fax or there is something wrong with your lines. Conect fax to another line then try again.
SOURCE: replaced Ink on Samsung SF-330 and still says install ink
There is something wrong with the cartrige head. First try to take out the cartrige and in the head there is contact points. You can try and clean it with a dry cloth.
SOURCE: Fax machine Samsung Inkjet Fax SF-360. Ink was
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
