Lawn mower will only stay running if I keep the primer bulb pressed. As soon as I stop priming the motor starts. I have a new air filter and fresh gas.
You need to check the fuel line for cracks/breaks. Check the fuel filter if it has one. If these two things are o.k., then you will need to clean the carb. It probably has debris in it.
Jim
Thanks for the rating.
When cleaning the carb., Use a Den Tek Brush, (http://www.drugstore.com/products/prod.a...), to clean the small portals in carb. Make sure the small screen in carb is free of debris.
Jim
