SOURCE: how do you set regular channels and low and high on a connex 3300
Combination of hi / low switch and the band knob, I believe C band with the switch on low will give regular channels.
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
SOURCE: after you convert the connex 3400hp from ham to
you will need a frequency counter, to show the channels. 1-40 and the others are allocated as frequencies. there are lists available showing ch1 band A is ??? so forth. there shouldn't be uppers or lower on it its just a AM/FM only radio NO SSB.
and these ARE NOT AMATEUR / HAM radios!!!!!!! these are EXPORTS...
