Nikon D60 Digital Camera Logo
Posted on Jun 07, 2009
Nikon D60 and a box on the screen
I have a Nikon D60 and now when I take a picture, a box with some info (camera model, metering, shutter, etc, etc) appears on the screen making impossible to look at the picture taken
I would like to know how to get rid of that box
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
406
Points
I am assuming that you are not talking about the "shooting info display on page 9 of the manual.
if it is the Photo info (sounds most likely) you can change that display by scrolling you can change your display by using the multi selector. From that screen i believe you hit the left tab by the okay key twice. Play around. when you get the display you want. just leave it alone and they will all display that way. That happened to me during a soccer game.. very frustrating.. see no way to lock it.
The shutter sticks when I take pictures. I have a Nikon D60
Hi da7macs,
This means that you have " Dust " accumulated within the shutter, i highly suggest for you to take your camera to the Camera shop and ask them to clean the shutter and internal lens for you.
i hope this helps.
2helpful
Can't viewb the LCD screen when shooting a picture! it's just black
The D60 works as SLRs have worked for half a century, showing the image in the viewfinder until you press the shutter. The LiveView feature which shows the image on the LCD screen is a rather recent development on DSLRs, unlike on point&shoot cameras. The D60 does not have this capability, which Nikon introduced with the D3 and D300.
Sorry if this wasn't the answer you wanted to see, but there it is.
2answers
How do I set it up on my Nikon D60 to use this remote?
I assume you're referring to the ML-L3 infrared remote?
Select Release Mode from the Quick settings display. Select Quick-response remote. This will make the camera take a picture when you press the button on the remote. Well, almost. The same focusing and exposure metering delays occur as if you'd pressed the shutter release button.
You can also use the Delayed remote mode for group pictures. This gives you two seconds to hide your hand behind your back before the camera takes the picture.
By default the D60 will time out after one minute if you don't press the button on the remote. Custom Setting #17 allows you to set a longer interval.
Jun 17, 2010 • Cameras
3helpful
A box showing information about the camera is showing
Press up/down on the multiselector to cycle through the different views of your pictures.
2helpful
I can't find the selftimer button and explain how it works
Press the Info button to get the shooting info on the display screen. Navigate to and select the Shooting Mode. Select the Self-timer (the icon looks somewhat like a clock with a single hand). Now, when you press the shutter button, the shutter will release after the delay. The length of the delay can be set via a menu option. The usual things about autofocus and exposure metering apply.
5helpful
I can't find my selftimer button on nikon d60. I an trying to take a picture of myself but I cannot find the button or make the one I thought work
Press the Info button to get the shooting info on the display screen. Navigate to and select the Shooting Mode item. Select the Self-timer (the icon looks somewhat like a clock with a single hand). Now, when you press the shutter button, the shutter will release after the delay. The length of the delay can be set via a menu option. The usual things about autofocus and exposure metering apply.
Nikon d60 - error. turn camera off and on again.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
