My keyboard will abruptly stop working. I have to restart the computer to get it to work again. Sometimes I have this problem intermittently or sometimes its non-stop. I can't find a driver to reinstall it or update it. I have uninstalled it and allowed the computer reinstall it on its own. Nothing is working. What do I do?
You posted lacking the OS installed, XP, VISTA, W7/8/10
why post lacking that KEY FACT,
why make helpers suffer you pain lacking this fact.
gee some PC run Linux, or even freedos in europe, direct from HP new or even OS/2
yah, so I will guess stinking dead, XP. since is sux so bad.
its a virus magnet with over 700 exploits, count those. ugh!
it's either hardware or software, in all cases,
easy no? 2 things. in all cases.
1: so use a USB keyboard, wow that work now?
if yes the internal keyboard is bad.
2: boot to linux USB stick does the keyboard fail now (inside)
then its bad, end saga.
3: lets say the linux works interenal
bingo XP infected, as all are now, all are,
and is not supported by HP or MS
bad internal keyboard.
its bad or key stuck which is bad.
or the cable inside fell off, (happens during bad service in bad shops.)
Are you Install voice control any software on your computer. cheek your control plan apps list.Are its automatically install uninstall them.
SOURCE: Frustrating Keyboard Malfunction (HP Compaq NC6000)
please tell the solution of this problem of keyboard
hp nc6000 mobile technology
SOURCE: Several letters on a keyboard have stopped working
Bring it back to the repair shop. They should replace the keyboard.
SOURCE: keyboard on hp dv7-1130us stopped working
This sounds alot like a virus i once had!
try a system restore to the point before these problems occured. if that doesnt work run a full virus scan. If that doesnt fix the problem you may have to wipe the hard drive completly.
SOURCE: Keyboard/mouse on HP Pavilion dv7-1240us is not working
go to start, control panel, performance and maintanance, system, hardware, device manager. If you see any question marks on any of the devices, then you need to reinstall the drivers for that device, but if there are no warnings then you may need check into it further.
