So PS3 loads fine but when I insert a PS2 game into the system, the PS3 recognizes the disc as a PS2 game, the screen goes blank, the red light on top of thr controller turns off and it just stays like that. If I press the PS button the 4 red lights on the controller just keep blinking. I can eject the disc, but I can't turn the system off with the power button, I have to switch it off from the back. This happened with Silent Hill 2, FF 12, Resident Evil Code Veronica and Prince of Persia: The Two Thrones. The PS3 has the latest firmware, I tried reseting the settings and I even tried formating the harddrive but nothing worked. The system reads DVD movies fine but I don't have a blu-ray movie or game to test out yet. What could be wrong?
i have the same prob with my pal 60 gig PS3 locks up when I try to load a PS2 game , have updated , still nothingi have the same prob with my pal 60 gig PS3 locks up when I try to load a PS2 game , have updated , still nothing
AnonymousDec 11, 2008
same problen here any solutions yet?same problen here any solutions yet?
You can't post conmments that contain an email address.
If your PS2 works fine with most
of the games and won’t play a few..Then you should try this trick to play them
too on your PS2:
Turn on your PS2 without
inserting any disc.
Menu screen will
appear like:
Press the (triangle) Button to enter Version
Information Menu that looks like
Highlight the Play Station
Driver as above and again press (triangle).
New screen will appear like
Highlight the Disc Speed
as above and press X button,to enter Disc Speed Menu
And set it from Standard to
"Fast".
After you set Disc Speed to Fast,Press and HoldReset Button to turn off your console.
Then again Press and Hold Reset
Button till the Blue Light turns on.
Remove the Reset Button and
Press it again.
Be
patient and wait till thegame loads itself. If your lens is in good condition then
it will play game in first go else try again till it PLAY your game. If still
your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens: Thank you and Good Luck!
Make sure that disc is cleaned, if you have an lens cleaning disc then run it. Depending on which system that you have...not all PS2/PS1 disc not compatable with PS3. Make sure that you have the right one if running an PS2 disc or check the compatability chart with Sony to see if that game can be played with your verision. The new slimmer PS3 unit are not compatible with PS2 disc which is wy the price is cheaper because they don't have the software/hardware added to play those games.
PLEASE VOTE IF THIS IS HELPFUL. GOOD LUCK AND THANKS.
you have to push the ps button on the controller again after the system loads the video game, for some reason (i assume compatability issues) the system breaks connection with the controller when it loads the ps2 discs. If this doesnt help get back with me
80010514 - An error occured during the start operation; Ps1 game swapped
using the eject function and then play pressed quickly - ps1 game
inserted again
If it isn't even trying to spin up, than it is probably a failed drive motor, or a driver issue. If it is connected to the net, try to install the latest drivers for the disc drive. If you aren't, or that doesn't fix it, you need to take it in.
I am having the same exact issue.....is there a fix for this yet?
