Televison & Video Logo
n
navdeepkang5 Posted on Feb 07, 2014
I have lost my dish set remote so how i can change the channels on the tv.i have tv remote.
arman_apego3
Level 1:
  • Contributor 3 Answers
  • Posted on May 26, 2014
arman_apego3
Contributor
Level 1:
Answers
Questions
0
Helped
1635
Points
If you lost your remote control for the dish simple call the customer service and asked for a new remote control. there are no ways to program a regular remote to a dish receiver box.
5 Related Answers
Anonymous
  • 171 Answers
  • Posted on Oct 04, 2008
SOURCE: REMOTE CONTROL
If you're lucky it will respond to code 10178, if not then you will need a rc64 directv remote and try the proview codes. The proview codes are worthless in any other directv remote other then the rc64 series.
Anonymous
  • 336 Answers
  • Posted on Sep 16, 2009
SOURCE: dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
Anonymous
  • Posted on Oct 06, 2009
SOURCE: dish remote wont change channels
make shure it is turned on the sat setting
Anonymous
  • 1274 Answers
  • Posted on Apr 25, 2010
SOURCE: I programmed my dish network remote to turn my tv on and off
You need to try a different code,505,506,516,523,526,566,573,612,627,647,652,653,654,655,656,658,659,664,665,667,669,670,679,680,704,717,730,738.....hope this was helpful....
Anonymous
  • Posted on Jan 09, 2011
SOURCE: my remote control only works
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Reset set t.v. to channel 60 for DISH system without a remote for RCA tv
Use the TV's original remote to put it back on channel 60. The
How do i change tv 2 with reciever or remote 1, lost remote 2.
Hi this isMike Houston of DISH Network and I see you have lost your TV2 remote. Until youget your 2nd remote you can put the receiver in Single Mode and putTV1 on the channel you want to watch for TV2 and then put it back in Dual Mode.I can help you in getting your TV2 remote so you can watch TV on both setswithout having to change the Mode setting on TV1, I will send you my e-mail andyou can contact me through there; [email protected].
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
2answers
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Dish remote wont change channels
1helpful
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
1helpful
Need to put tv on video 2 mode to use ps3 and no remote
Have you tried running through the channels until they wrap around and start over again? Alot of TV's will throw the AV inputs in there before the first broadcast channels.
If not (and you're gonna hate my answer, but be kind to the messenger please!), you may have to purchase a new remote control from the manufacturer, which can be exorbitantly priced. Most 'Universal' remotes will act just like your Dish Network remote, and you will probably not be able to use any of your set's advanced functions through them.
I would recommend searching the web for the appropriate replacement remote control, you may get lucky on eBay and save a few bucks. Hope this helps!
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
1helpful
2answers
Won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
