When you insert the SD card, the photo importer opens in German, not handy since I'm not fluent in German
SOURCE: "please insert memory card in GZ-MG130U CAMACORDER
Hi there.
The hard drive will be full so you will need to transfer all your videos to your PC then format the hard drive in the camera's menu, make sure the SD card is removed before you format it.
Good luck and thanks for using FixYa!!
SOURCE: Can't insert SD card Evesham Voyager laptop
pls parchesh the cad redar and install the card redear in your laptop in usb slot and fist card is add your card reader and copy all file of data in your laptop and save it you have allso save the pendirve and trnsafre ayour data in other laptop are destop .......................ok
SOURCE: I just purchased a Garmin
First do a back up of all your GPS data.
Then erase the lex pkg on the Garmin (the limited version that came free)
Then insert your language sd card it should ask you if you want to load the language pkg
to the garmin say yes then remove the card and it should all work ...
aztech
SOURCE: Cannot transfer photo from my SD card to computer
either your pc card reader or adapter for sd card is at fault here....but try this way connect your camera to pc (using usb cable)...go to my computer see the new device (camera) click on it to open ...your pix are there now copy & paste (click & drag) to your folder on the pc...hope this is helpful...feel free to rate
