SOURCE: BT-10-B Bunn Thermofresh that will not heat or fill pot
Lots of times minerals clooect on the heating element and inside the heating chamber. The easiest thing to try is to put white vinegar into the filler, displacing some of the water into the pot. Leave this to soak for about an hour, then flush with several pots of water until the vinegar smell cannot be detected in the water. Make sure that the switch on the side is "ON". You may have an indicator light. The switch on the upper front is for the warmer. The reason you only got a partial pot of water is that the reservoir wasn't completely full. Once you have filled it completely, you should fet a full pot out for every full pot in. If all of the above gives you no relief, you may need to test the heating element for voltage and continuity. If it tests 'open', you will need to replace it.
Good luck, --W/D--
SOURCE: Bunn model CWTF15 brews coffee but coffee not hot
Check the setting on the thermostat behind the front panel, it might not be set correctly, turn it all the way high the back 1/4 turn.
SOURCE: When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
SOURCE: I have a Bunn CWTF15. Water does not fill the
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
