Continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again. Can help me?
On my eZip 1000 scooter, in front of the battery pack, there is a compartment that houses the controller & assorted connectors & wiring. There is also a plastic housing that contains 2 fuses. Check, inspect & test the fuse(s) with an ohm meter for continuity. If all other components are functioning normally, it's probably the fuse(s) that need replacing. Hope this helps.
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
Defrost heater bad, defrost thermostat bad or Defrost timer. Defrost heater and Thermostat can be continuity checked. Defrost thermostat can only be checked if at freezer temperature. Both should show continuity if good. If those two test good the process of elimination means it's the defrost timer. Always unplug refrig when performing these checks
When the plotter goes through its initialization, it stops, the printheads move to the right side and the window displays "switch power off, check printhead path (2)" I've turned the power of an wiped things down, I've unplugged and then restarted but continue to get this message. What do I need to look for or do to get it back on track?
