Electric Razor Pocket Rocket Ride-on Motorcycle Logo
A
Anonymous Posted on Feb 07, 2014
My razor motorcycle pr200 motor won't engae - Electric Razor Pocket Rocket Ride-on Motorcycle
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
Razor pr200 pocket rocket. the tire is moving when i lift it up but when i sit on it it wont move
#1 check your power voltage on your batteries #2 you need to check the power to the electric motor - #3 possibly replace the control module - #4 possibly replace the throttle
Razor electric scooter e 300 battery charges but won't run
first check to ensure the batter has held the charge you put into it. Just plugging the charger in does not mean the battery is holding the charge. If the battery is bad, it will drain as fast as you put it in. if the batter holds a charge, should be able to disconnect the charger and battery will show charge. if so, you have a bad connection or motor.
Jun 29, 2013 • Motorcycles
Changed battery but won't turn on
It could be the starter motor it self. Also check the ignition switch just to be safe.
ITP tires
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
1helpful
I have a 42cc homelite chainsaw that I put on my razor mini chopper when there is weight on back tire the bike won't go but as soon as I pick up back tire it will spin how do I solve this problem
If you replaced the motor on the original razor with the chainsaw motor, you may have a gearing issue as the load on the chainsaw is much less than the load on the razor.
2helpful
Driver webcam for MSI PR200
go here
drivers.softpedia.com/get/SCANNER-Digital-CAMERA.../MSI-PR200-YA-Edition-Bison-Webcam-Driver-63207.shtml
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
