Try this link below
http://support.casio.com/en/manual/009/qw1000.pdf
SOURCE: need instructions manual for my solsuno watch
you can go to solsunoworld.com and visit the order page, you will find the instruction next to any genuine solsuno, our movment is used by zeon for their zeon tech
You can contact me for info via solsunoworld.com
Claude
SOURCE: Casio Triple Sensor ATC-1200 Module
Charlessmall: I have a downloaded copy of the Casio ATC 1200 watch manual. I misplaced the original and downloaded it several years ago when it was still available. E-mail me at [email protected]. I'll e-mail a copy to you.
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general
procedure to switch the ATC 1200 from meters to feet. You can also
switch the ATC 1200 (1170) from C to F. This is very helpful if you
change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the
watch to come up. This is because of a race condition when the watch
gets power. To fix this, look for the AC mark on the inside of the
watch. Under this marking, in a little space to the left, are two
copper pads. Short this out with a small screw driver to get the watch
to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter
abbr for the day is at the top. Also, if you cycle the mode button, it
is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to
the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
SOURCE: i need the instructions manual
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
SOURCE: how do i find a new watch strap for my casio wva 109hu
try this link for your watch strap
http://www.watch-band-center.com/watchstrap-s1237h243-CASIO-Straps-Metal.html
