SOURCE: Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
SOURCE: D-Link DP-300U
The DP-300U can be accessed with the password SYSxxxx, where "xxxx" is the last four digits of the unit's MAC address. The MAC address can be found printed on a sticker on the bottom of the unit.
SOURCE: can't reset password D-link DP-300U
Can anyone tell me, what IP Address when reset to default? thx's...
SOURCE: DP 300U
DP 300U's can get be pretty uncooperative when attached to a different router. One solution is to reset the DP 300U to its factory settings. Use the PS Admin software to do this. (If you lost the PS Admin software, you should be able to download it from the internet.) If the software prompts you for a password and you do not know it, try "SYSXXXX", where XXXX is the last four digits of the MAC address located on the underside of the print server.
After you reset the DP 300U you will need to set it up from scratch, a process which is not particularly intuitive. Refer to your "Quick Install Guide" (download it from D-link's web site if you don't have it anymore).
SOURCE: hi , please i have forgot my password Dlink dp 300u ,can you help me please?
Try using the psadmin software to do a factory reset. If it demands a password to do this, try using "SYSxxxx" (where xxxx stands for the last four digits of the MAC address written on the underside of the server. If you don't have the psadmin software you may be able to download it off the internet. After doing the reset you will need to follow the Quick Install Guide to set up the server. If you lost the Quick Install Guide you can download a new one from D-link's website. The following link may also be helpful: http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
