I have a DD603 Double Drawer Fish.and Paykel dishwasher. I get the F1 fault coming up every 2 to 3 weeks. I leave it alone for a week or so. Turning the power and water off for a couple of weeks.I turn the water and power back on then it works again but the same cycle happens again. Any ideas anyone?
SOURCE: with a DD603 d/washer , the F1 sign flicks once the w/cycle ends
F1 is a fault that occours when a waterleak is detected if oyou rmeoveth elower drawe there shoudl be a trouble shooting guide taped to teh back wall inside,very helpful
SOURCE: fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
An F1 fault means that the Mains Filter board on the bottom pan has detected water, a leak. There are, unfortunately, a few possibilities of the cause of this. Most likely it is bad lid motors (the motors that lift and pull down the lid to seal the drawers) or a broken Link Support. This is the plastic piece that hold all the hoses and wiring out of the way when you open and shut the drawers. A portion of this Link breaks free and gets lodged in between the drawer and the lid causing water to pour out into the lower pan when the unit is running. You'll need to have a Tech out to take a look at it, if you can find one. Good luck.
