Nikai DV7000 Camcorder Logo
A
Anonymous Posted on Feb 07, 2014
The camara is locked - Nikai DV7000 Camcorder
Cobra digital camara dvc910 says card lock/how to fix this
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 29, 2012 • Cameras
Why my camara reads card protected.,,,i pearches a memory card and the camara doent work
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
My camara has a display that says Card locked >
There is a slide button on the side of the card. One direction locks, the other unlocks. If this doesn't work, make sure you didn't buy an SDHD card for a camera that only uses SD. The error message shows if it's the wrong card. That was my mistake last week.
1helpful
1helpful
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 • Cameras
1helpful
The camara said camara memory locked i need to know how i can unlocked
Did you using SD card?
Try this:
1. Take out your memory card from the camera.
2. There's switch to lock and unlock on the memory card.
3. Just unlock it, and put back your memory card.
Hope this help! PM me if you have another questions.
No format memory card
Make sure the lock switch is set to off on the cards you are using. That would prevent you from using them.
2helpful
Camara lock
Take out the memory card there is a little lock on the side of it. move the lock over and this should fix your issue. hope this helps
2helpful
Card locked
Make sure the SD card's lock slider is in the unlock position.
I might be overlooking the simple of it. But sometimes that's all it is.
If you can, try another card.
Orite camara
driver
Hi , I lost CD program of Orite I-CAM _VC Model 360 and then I can not use untill download the program.You are kindly...
Top Nikai Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Nikai Video Camera Expert? Answer questions, earn points and help others
