This can be caused by the toner cartridge being completely empty or the shipping strip not having been removed prior to installation into the printer. Hope that it is one of these problems because if not, then it could be something much more serious/expensive to fix. For example, it could be the laser itself has failed, so the laser unit would need to be replaced. It might also be the charging roller has failed (but usually this would cause a printout with defects rather than a completely blank page). You might also have a problem with the High Voltage Power Supply.
SOURCE: prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
SOURCE: printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
SOURCE: Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
