NorStar M7310 Corded Phone Logo
A
Anonymous Posted on Feb 06, 2014
Resetting company voicemail on norstar M7310 - NorStar M7310 Corded Phone
1 Related Answer
Anonymous
  • Posted on Oct 15, 2008
SOURCE: resetting company voicemail
Can someone please help me?
My company has an M7310 (Year 2002 model) and we're trying to remove a person from the directory and the voicemail box.
I've tried these instructions, but Feature 9-8-3 doesn't work. It shows "Invalid Feature".
Feature 981 works, Then selecting 'Other' softkey which displays Log:
I don't know what the password is.
I tried typing in 10020000 since our extensions are 4 digits, but no luck.
HELP!
I have a Nortstar M7310. The Main Greeting is set up and it gives 4 options and #4 is for a list of company employees. I need to re-record this since we have new staff and can't find it.
Reset voicemail box and when the set up the voicemail on there phone and record there greeting make sure they record there name as well then it will play the extensions recorded name
Message indicator mail voicemail
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
I'm a new employee. I don't know the former person's password and no one else does. How do I reset the password on a Norstar M7310 telephone system if I don't know the old password?
Have your system administrator go into voicemail programming and reset the mailbox password. The default password will be "0000".
I hope you understand that having passwords in the first place is a security measure, so I will not give directions for hacking into your companies voicemail system.
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
1helpful
*talk busy Norstar M7310
reset your voicemail, power cycle and see if that clears the problem.
2helpful
Automated Attendent
Norstar Voicemail for 6.0 or less
Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG:", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Record the Company DAY & NIGHTGreetings:
1. Press AA
2. Press GRTG
3. Press GRTG
4. <Display> Greeting:
5. Enter 1 for DAY Greeting --- Enter 2 for NIGHT greeting
6. Press OK
7. Press REC to record.
How do I enable the company directory on the NorStar Meridian M7310 phone?
When you add a voicemail there is an option for DIRECTORY, say YES and that will set up a directory.
M7310 NORSTAR PHONE
Does the voicemail pickup at all? Try rebooting the voicemail
2answers
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
