My DVD recorder has started to give error's after a dvd is recorded and at times will not finalize the dvd after it is recorded
There are a few possible reasons why your JVC 150 DVD recorder may be unable to finish a disc or is displaying an error message indicating that a disc is an ad:
Compatibility of the disc: Not all DVD recorders are compatible with all DVDs.
Your JVC 150 DVD recorder might not be compatible with the DVDs you've used for years.
A dirty lens may prevent the DVD recorder from adequately reading the disc.
Even if a lens cleaner helped, if the issue still exists, it might be required to have the lens cleaned by a trained expert.
The CD might have been scratched, damaged, or otherwise corrupted, rendering it unreadable.
Firmware issue: The firmware of the DVD recorder may be outdated or malfunctioning, causing it to not be able to read or finalize certain discs
Hardware issue: There may be an issue with the hardware of the DVD recorder such as a malfunctioning laser head or reading mechanism that is preventing it from reading or finalizing discs.
