Vtech 5.8GHz Analog Cordless Phone Logo
A
Anonymous Posted on Feb 06, 2014
Phones manuals is it possible to go back and view the numbers i dialed the day before on my vtech cordless phone?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Jul 27, 2014
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428359
Points
622693
That depends on the model of your VTech phone. Enter the model number into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
5 Related Answers
Anonymous
  • 65 Answers
  • Posted on Jan 26, 2008
SOURCE: How do you leaving a voicemail for your answering machine on the Vtech cordless phone?
ARE YOU WANTING TO RECORD A MESSAGE THAT CALLERS WILL HEAR OR ARE YOU WANTING TO LEAVE A MESSAGE FOR SOMEONE YOU CALLED?
Anonymous
  • 95 Answers
  • Posted on Mar 28, 2009
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
nature_lady1
  • Posted on Dec 18, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Anonymous
  • Posted on May 19, 2010
SOURCE: 5.8GHz Cordless Phone with Digital Answering System & 4 Handsets: my vtech cordless phone says connecting and i can'...
my vt phone is lock and need to unlock it help
Anonymous
  • 7191 Answers
  • Posted on Oct 27, 2010
SOURCE: I need an instruction manual for VTech Cordless
You can download and print the instruction manual for VTech ia5874 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
1helpful
What number can I dial when Iam not at home to get messages?
Dial your home number.
If you need a manual, enter the model of your VTech DECT 6.0 system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Review last number dialed
Enter the model of your VTech DECT 6.0 phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Cannot set up for remote call-ins. call my phone number, once my message comes on, I dial *19 but phone does not respond. What should I dial and when?
Since you declined to specify the model of your VTech answering machine, enter the model number into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download the manual.
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
My cordless phone is clicking when i dial.
Jeanne fist a background history lesson - there are two dialing modes in existence one is pulse or earlier on was known as decadic dialing. This is where the phone would break the connection a number of times to represent the number dialed. Remember the old dial phones that you would dial a nine and it would spin around back to its original position and would break the line nine times . Very Very slow way to Dial.
now to the 21st century - Tone dialing was invented also know as multi tone frequency dialing MFTD by sending two frequency tones numbers and symbols could be encoded to pass through the phone line quickly.
Solution
press menu / select option
select telephone settings
see picture below from user manual
Dialing sounds like rotary and will not allow extension choices
Since you neglected to specify the model of your VTech 5.8GHz phone I can only suggest you enter it into the search box here to download a copy of the manual to see how to switch from pulse to tone dialing.
Saving phone numbers
hello tjfred.
try here see if your phone listed 5.8 GHz VTech® then click
more info link when you see you phone for the manual.
riz.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
