Hi!!!
I've brought new 2.1 subwoofer. But left satellite speaker gives no sound .
But at the same time left speaker of my headphone also does not work(but I'm sure headphones are working properly).
I'm using MSI PM8M2-V mother board and my sound driver is Realtec AC 97 Audio.My O/S is windows XP.
What I did:
- unplugged and replugged the cables properly
-checked the sound settings & sound balance -ok...
-uninstalled & reinstalled the audio drivers
- Tried a good desktop speakers - but it's left speaker also didnt work
What should I do?? Plz help
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
It can't be the plug because the headset would work. If it is not the equalizer settings, I would return the card and try another one.
