Question about Nordic Track NordicTrack Commercial 1500 Treadmill
Nordic track will not lock in upright position
SOURCE:
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
  • 5370 Answers
SOURCE: My Nordic Track T7si is
There is a reset button.Locate the reset button near the power cord. Set the button to the reset ON position.------slide the reset button off/ on.then see if that makes any difference.-------
But if that is not helping and display is freezing again n again then remove battery from the display panel board.Clean the battery and re-insert.If that's not helping, try with new set of batteries.If syill the same problem then is faulty control key pad board.Its shorting
, it has to be replaced.------- On most machines when you press a button on the console you
get a beep sound. If you don't get a beep on the elevation up or down
and you do on the speed up and down, it could be the display overlay/keypad.
If you see the elevation go up on the display but the unit is not elevating
it could be the motor or wiring.
Or last but not least, the electronics not being
able to send the signal out of the electronics.---------
This should help.Thanks.Helpmech.
Posted on Jul 02, 2011
SOURCE: how do I get my
theres a switch available 4 d same.. Right nxt 2 d 1 u used to move up
Posted on Sep 24, 2011
ercupa190
  • 12223 Answers
SOURCE: How do I disassemble the Nordic Track t5 zi for transporting?
Please read you owner manual.
If you do not have please go to www.nordicktrack. com then customer service and then parts & manual, give you model, etc, and download free and read the section how to fold and viceversa.
sincerely
Posted on Dec 09, 2011
loriwadle
SOURCE: nordic track exp 1000 treadmill console
Hii sumazone, was just wondering if you ever found out what was wrong?? I am havng same problem. thank you
Posted on Nov 16, 2012
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
My Old Nordic Track Pro is Broken, Can It Be Fixed?
well it possibly could be fixed but finding the person that will fool with it might be close to impossible so perhaps the trash bin and buy a new one .
Jun 13, 2015 | Nordic Track Exercise & Fitness
Nordic track treadmill is stuck up in space saver position
see the video and proceed , use the common sense. God bless you
Oct 07, 2012 | Nordic Track NordicTrack Treadmill, A2550
sincerely
Dec 09, 2011 | Nordic Track NordicTrack T5 zi Treadmill
How do I get my nordic track 7500 down from it's standing up position?
Sep 24, 2011 | Nordic Track NordicTrack Elite 7500...
BUYER BEWARE!! I purchased the Nordic Track C2500 in 2009 and after 2 years of moderate usage (105 lb women walking 3-4 times a week) the console stopped working. None of the buttons respond and it beeps...
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Sep 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
260 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
