Reset factory settings on Infoprint 1312
To reset IBM Infoprint 1312 to factory settings, do following:
1. disconnect USB and network cables
2. switch power button to OFF
3. open toner door
4. press and hold both buttons (continue+cancel)
5. while holding buttons, switch power button to ON
6. keep holding buttons until printer initialization is finished (LED error is on)
7. close toner door
8. switch power button to OFF
Connecting printer in network:
Now you can connect printer with network cable, make sure DHCP works in your network. Switch power button to ON. Printer initialization should also obtain IP address from DHCP.
You can look in your router DHCP clients list or you can try to use software delivered with printer to find printer in network :)
When you go to IP of printer via browser, it will allow you to change some settings. Username to login is usually MarkNet, password is yours :)
This is all my personal exprience, it definitely works for this particular network printer :)
