Boating Logo
Posted on Jun 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 Mercury Mariner 9.9hp outboard motor
Where is the forward and reverse on 1999 Mercury Mariner 9.9hp outboard motor manual start?
  • Anonymous Mar 24, 2014
    does not pump cooling water through
Anonymous
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on Jun 27, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
207
Questions
0
Helped
119756
Points
418
Should be on the side with a lever but could you give me more info please
I have a 1999 200hp Yamaha outboard motor idles fine everytime I put in gear stalls at low rpm fine at high rpms and idles fine in gear loe rpms stalls
This may sound funny, but for a while, Yamaha put a steel bolt in the aluminum casing on the side of the motor. dissimilar metals caused extreme corrosion inside that affected operation. Check out Boating forums on Yamaha.
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
1helpful
Where might I find a working fuel pump for a 1966 Mercury 3.9 hp outboard motor?
there is a pump for sale on e-bay --seller is western furniture (1918) used condition for $25.00 us 2 people watching it but it has a buy now tab
I found this by going google and typing in --fuel pump for mercury outboard motor 3.9 hp-- and the site is www.ebay.tv>sch>ebay-motors-
mariner is also a part of the mercury range so check for mariner 3.9 or 4 hp parts
Sep 11, 2016 • Boating
1helpful
What year is serial #od272328 on the above listed mariner eight outboard motor
http://forums.iboats.com/forum/engine-repair-and-maintenance/mercury-mariner-outboards/270818-mercury-serial-year-hp?t=264118
Dec 16, 2015 • Boating
45 hp mercury mariner outboard motor wont go into neutral or reverse is stuck in forward drive when started
will probably need a manual on your motor for this problem. perhaps careful disassembly will reveal the problem.
Jun 03, 2014 • Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 • Boating
Gear shifter for 40 h. p. mariner outboard
With your lower unit off have someone shift the engine into forward while watching the gear shift select shaft's rotation,let gearshift remain in forward,now place your lower unit in forward and reinstall. In the future just put engine in forward when installing a water pump as there won't be a need to move gearshift
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
