I can turn on the korg normally, but the screen stays frozen on the"KORG" display. I cannot turn it off properly.
Did you try boot from the CD with the OS? is it the Same? Did you replace the hard dirive with another?
Is the HDD/CD disk light flashing or illuminate during power up? It should!
Additionally, do youhave the manual, near then end it tells you some keypress actions on power up so it will boot from different areas or devices - ie CD or internal hard disk (operating system boot). It can get confused if you've got a dead disk or a corrupted boot area. There is a repair option once you get it to boot. install OS. IF that does not work, then it a hard disk or disk cable or power issue, If Disk access lamp doesnt come on it means no disk detected. There are some pretty flimsy cables inside which can fail or get dislodged to cause isues. Let me know how you get on. recently my disk was dead I then broke the data cable. Solved it by booting from CD, This installs OS and then swapping the hard drive to the CD cable. on reboot it was normal. I then replaced the ribbon and swapped every thingbacl. Fully sorted.
