Wash program starts with 125 minutes to completion and show "wash" counter get to 1 minute and the cycle gets stuck on "wash" and continues like this until cancel button is pressed and I then have to select rinse/spin program button to complete the wash. before it use to wash/rinse/spin all in one. Any idea, is it the bearings or drum going or something like a coin or button stuck in the motor or cogs somewhere. help or advice much appreciated.
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
I can use other programmes okay like rinse/spin and only when I use a wash programme that the timer counts down the cloths are washed but does not move on to the next cycle of rinse and spin. So I dont think it the control board but more like something is not triggering the next stage in the complete wash cycle. Some of the suggested solution like bearing or heater element blow or disconnected might be the cause. Will call a repair man to check it out. Thanks for your suggetion and help with this.
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
SOURCE: won't complete a wash cycle
sounds like your bearings have gone and thew reason it just keeps going and going is because the heater has blown so it will not move on because it is not heating so u will need new bearings and a heater and that is not a job 4 a novice call an enginer good luck
SOURCE: drum doesn't really rotate on wash cycle.
No solution, but I have the same or similar problem - bootom agitaor works, top doesn't. Also softner spots clothes during spin cycle - help - I can't afford a repairman!
SOURCE: My machine does half a
susan,
the way you describe it is typical of a faulty heating element.
remove rear inspection panel and if your lucky you will see a broken spade connection at the heating element.
if no wires are broken an element will be required, part number 1604486 or C00094715, price aprox £20-30
hope this helps
Problem fixed the electric supply wire connected to the heating element terminal had broker away put a new end connector to the wire and pushed it back on to the terminal connection works a treat now. Dont understand why the wire does not have a heat protective sleve over it so protecting it from heat damage and amking it brittle.
