My c350 bizhub does not come with either the usb port or the parrallel port but with Ethernet port. how can it be installed?
You need a Ethernet cross over cable. plug that into computer the other in to copier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta bizhub C252 printer Problem
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
SOURCE: printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent?
If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g.
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
SOURCE: I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
SOURCE: How do I install Konica
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
