Cannot send scanned documents to email address
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
SOURCE: Unable to create an email address on a Imagerunner 3220
Hi Keeyan.
Fist you will need a send kit only supplied by your dealer.
If this funcktion is inable follow these steps.
Press the user button(it is the button with the star)
Select system settings,network settings-in network settings go down wit the arrow until you get e-mail/i-fax settings.(If it is not showing here or in tcp/ip settings the send kit might not be enabled)
In e-mail settings enter the smtp server name or ip address(you will find it on your computer in outlook under tools and acounts)
In the email you can enter a email address supplied by your network adminitrator.
If you have a DNS server insert the ip adress of the DNS in TCP/IP settings.
Make sure you IP addres is also correct.
Then you are ready to go
SOURCE: The scanning feature doesn't work
do a clear all to the machine.first do a backup of the data
SOURCE: How can I scan a document and send it in a email?
use 75dpi
open your email, click attach and find your scanned .jpg file
send as usual
SOURCE: I am trying to scan and email a document to
better check your settings. IP Address should be static& the protocol should be Windows SMB.
