engine starts and runs and drives and is OK??????????
all else works? head lamps work key off and on?, parking lamps 4corners, TURN sigs,brake lamps , wipers, best it tell what works and does not work on any electrical fail post, scan the car is first if fuses test good;.
PCI to voltmeter cluster is PCI data.
PRNDL cluster status is PCI data
even the radio is PCI connected so if wired wrong OOPS> PCI dies.
rtm
read the service manual see all wiring there.
https://eautorepair.net/Marketing/Default.aspFUSES ARE FIRST, <<< repeat 3 times.
fuse 14,19,20,24 , BCM has 4.
14 is BCM memory fues, IOD.
