Needs to unlock
SOURCE: how do i get photos off the sony ericson xperia
Rather smartly, Sony Ericsson's installed its PC Companion desktop software on the phone itself, so the first time you hook it up to your computer you'll be prompted to install the tools.
Once installed, you're able to then install yet more SE software, like its Media Go tool, a Support Zone helper and Sony Ericsson Sync - the company's own way of ensuring your phone numbers are all backed up in case you drop your phone down a drain while out on a drunken escapade. Or, in the case of the Sony Ericsson Xperia X10 Mini, swallow it. Media Go is refreshingly simple for a supplied app - it's little more than a fancy Windows Explorer screen, letting you select PC folders of your music and dump them onto phone, or organise your mobile playlists and subscribe to podcast feeds. Fortunately, you don't have to use it at all - the X10 Mini will pop up as an external drive when connected to a PC, for your easy dumping of media.
SOURCE: sony ericsson xperia x10 mini pro unlock code
direct unlock your Sony Ericsson X10 mini pro using your cable and this server http://www.fonefunshop.co.uk/Unlocking/unlock_sony_ericsson_x10_server.htm
unlock takes approx 10 seconds, which is a hell of a lot faster than waiting for an unlock code.
SOURCE: Toi can tim code Unlocked Sony Ericsson Xperia X10 Mini E10i
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlocking.com which is doing good service .....you can approach this website.
SOURCE: how to transfer contacts from
This can be done in a few ways: synchronizing with Outlook/Lotus Notes, via SIM card or sending the contacts manually as vCard files. I've recently bought a Sony Ericsson Elm and wanted to transfer contacts from my old Nokia 6233. Take a look at my solution here:
http://gsmdna.net/sony-ericsson/how-to-transfer-contacts-from-nokia-to-sony-ericsson/
Hope it will work for you too!
SOURCE: i have asony ericson xperia x10 and i need a
YOU CAN UNLOCK YOUR SONY ERICSON HERE THIS SITE.
