SOURCE: panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
SOURCE: Remove misfed paper code J93
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
SOURCE: Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
SOURCE: IP address problem
What problem? Need more info! On the Panasonic brand, you input the IP address through the "function" mode- "general" settings... go to last menu item "key operator" the code should be 3 or 4 zeros. Then go to the IP address item and enetr in the IP adress. Now you MUST TURN THE MACHINE OFF AND BACK ON TO LOCK IN THE IP ADDRESS! Go back into general setting and "print general settings" to see if it's still the same address.
SOURCE: Have a Panasonic Workio 8020 machine, is showing
Change copier to Fax mode - Function button no. 7 (set mode) and then No.1 (user parameters)
