Timberland Steprock Men World timer Model QT7169103 Logo
B
BHADRESH PANCHAL Posted on Feb 06, 2014
Can you give me a detais of button cell - Timberland Steprock Men World timer Model QT7169103
Paw-1200t
may be some dust inserted into the watch which prevents you to press the buttons .
another prob might be low battery. put your watch in sun in order to give some power to your solar battery
1helpful
As I said in the video, not exactly sure happened but it freezes on that screen and then after a while returns back to the normal time screen
In the manual there are instructions that may give you a hint. Sometimes there are combinations where you hold more than one button in at the same time. Sometimes there is a Master button that needs to be held in while you cycle another button in and out to choose function. There is also, probably a third button to make changes after you have chosen the function on the screen....good luck playing with it!
Jan 01, 2013 • Watches
I have a Luminox 3050/3950 series which stopped working after almost 2 years from buying it.I thought it was the battery so I tried to change it my shelf, but even after the replacement of the battery the...
Generally after two years power cell life will over.
> are your replaced same battery? check the voltage of power cell _1.5V
> Observe that seconds needle giving any jerks? if its trying to move its overhaul faulty, give it to good service center for overhaul.
> If its not at all moving at all it might be coil or PCB faulty..
3helpful
2answers
HI, I brought my OTS sports watch in China, i forgot we have 12 hours differents in US, so now in US is 10:31am but my watch is 22:31, i tried so many times and can't change it, please...
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Aug 18, 2010 • Watches
How do i set the time and the alarm?
click the mode button 3 times and hold the adjust button until it gives you an option to change you change it by using the mode button to choose min.s or hours and the time memo button to go down in time and the receive button to go up in time and then click adjust to set it then you just click the time memo button to turn it on and off a few lines on the top right corner should tell you if it is on or off.
1helpful
How do I get my coleman watch off 24 hour mode?
I don't know the detail of your watch operation but this may help:-
The "mode" button steps the watch through a series of settings which can be adjusted by pressing one of the other buttons.
Keep pressing the mode button until you reach "24" or something similar and then experiment with the other buttons until it changes to "12".
It may require a little patience but in the absence of any instructions you should be able to work out the correct sequence.
Good luck and don't give up!
Mar 17, 2010 • Watches
Juicy Couture 'Dalton' Watch i cant figure out how to open it to wear
Hope you've already got it figured out, but if not... you have to give it a good pull on the back of the link bracelet. Hold it with your fingers on the edges (sides) of the links and give a strong pull just to the side of the round button on the underside of the watch bracelet. One side comes off before the other, so if it doesn't click open, try the other side of the round button. It'll open half way, then do the same thing on the other side. You won't hurt it :) Beautiful watch. Mary
Top Timberland Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Timberland Watch Expert? Answer questions, earn points and help others
