Question about Timberland Steprock Men World timer Model QT7169103
My analog time stopped. kindly help to find suitable button cell
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
Mar 31, 2013 | Casio Watches
How to set the time and analog time of CASIO ILLUMINATOR0 SGW 400 h
set the digital time: press and hold upper left button, then the seconds blinks use the lower left button to choose what are you going to set ( the one that blinks is the one that can be set ), use the upper right button to set. when your done. press the upper left button once.; set the analog time: from the time mode of the digital press mode until you see the "H.SET" , then the time of the digital appears, then use the upper right button to set the analog time, when your done just press the upper left button once and use the lower left button to bring back the time mode. i hope this will help you a lot.
Aug 13, 2011 | Watches
My radio controlled watch is exactly half an hour fast according to the hands, but the internal clock appears to be correct. This happened when I tried to adjust the watch to Canadian time
If I understood correctly this watch have a analog watch display ..and it is half an hour forward..but when you set timing or the alarm it behave normal ..and so the internal one is correct ..but just do not display the correct time on the analog one ...If it do not have any means to correct manually the analog watch ..I advice to try to remove all power and stop the indicators at the exact time ...(a sharp hour...) and power it back after the exact time it is forwarded ....This way the analog clock will be stopped..and the internal one will go on and will adjust at the spot by the radio time ..and you will have both timers in correct display ...If it does have buttons or so in the back ..try to correct them by hand ..
Jul 12, 2011 | Watches
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
Mar 08, 2011 | Caravell Bulova Caravelle watch
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Aug 21, 2010 | Casio Watches
How do i turn back the hands one hour
The analog clock hands on the Casio 2747 will only turn in a clockwise direction, but there is a way to speed them up when you have to move them far around the watch face.
1. In Timekeeping mode (i.e. Date is shown in the digital display), push button "C" (bottom-left) 6 times to enter Hand-Setting mode.
2. Hold down button "A" (top-left) until the digital time starts to flash.
3. Press button "D" (bottom-right) to advance the analog time by 20 seconds, and hold down button "D" for High-Speed.
4. Alternately, for High-Speed, press button "D" (bottom-right) and button "B" (top-right) together at the same time, and then let go. The hands will continue to move automatically. Press any button to stop them BEFORE they arrive at the desired time, then press button "D" several times to arrive at the time of your choosing.
5. Press button "A" (top-left) to exit.
6. Press button "C" (bottom-left) if you want to return to Timekeeping mode.
Oct 28, 2009 | Casio DBW30SG7AV Databank Analog Watch
Can't adjust the date on a digital watch
These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
http://img261.imageshack.us/img261/6784/manualr.jpg
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
Good luck.
PC
May 26, 2009 | Watches
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Apr 14, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Timberland Steprock Men World timer Model QT7169103 Logo
Top Timberland Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Timberland Watch Expert? Answer questions, earn points and help others
