SOURCE: Hi I cant configure my router D-link DIR-300
This definitely worked for me. To find out your computer's MAC address, just go to start, then click run, then type 'CMD'. When prompted, type 'ipconfig/all'. Find your ethernet adapter local area network connection, and underneath you will find a lablel titled Physical Address. This is your MAC address and should consist of 6 pairs of number/letter combinations. Then connect your computer to the modem, eithe wirelessly or directly and point your browser to 192.168.0.1. Under Setup click Internet Setup and then click Manual Internet Connection Setup. Under Internet Connection Type, select Dynamic IP (DHCP), then under MAC address, type in the MAC address of your computer. Click Save Settings and Presto! It worked for me.
SOURCE: How to restore D-Link DIR-300 router to factory defaults
T%here is a small recessed hole on the back panel of your router. You can use something like a straightened out paper clip to push into this hole, holding it down for approximately 5-10 seconds. Your router will then be reset to 'Factory Settings.
SOURCE: how can i configure my d link dir 300 on my
start - run- type in cmd- enter- type in ipconfig /all will show router address should be 168.192.1.1
open internet explorer and type that # in the address bar
should connect with router
leave password blank or type in password for the password
enter the router setup and configure router to your preferance
SOURCE: cannot get d-link dir 300 to boot up using the
It may be 192.168.1.1.
Click on "Start" on the bottom left corner of your screen and then "Run." Type "cmd" in the Run box and click on "OK." A black screen will appear with a blinking cursor. type "ipconfig" and you will see your IP address. The gateway number is the IP of the router. Do not use the quotation marks when you type in the run box.
If you need to reset the D-link, here is how to:
There is a button on the back that is labeled reset. You need something small (paperclip) to stick through the hole to hit the button.
I think you just need to use the default settings.
Default User admin
Default Pass admin or (none)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: HOW TO SET PASSWORD ON
You can set both network and administrator password using the set up wizzard.
Note to set network password choose WEp (or preferably WPA) encription.
Default User admin
