Honeywell QuietCare HCM-6009 Humidifier Logo
C
Cas Gabriel Posted on Feb 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lights on but no fan, no mist
The humidifier has been working fine but turned it on a couple days ago, lights came on but no fan, no mist. Recently cleaned and put in new filter and it was working without any issues. Tanks are filled with water, unit is sitting on level floor. I unplugged it, turned it off for a day, tried higher setting...no luck. All the lights come on. Thanks
  • 3 more comments
  • Cas Gabriel
    Cas Gabriel Feb 08, 2014
    sorry I posted this in the wrong place: "fiantella...can you please explain to me how to remove the humidstat. Do I have to unscrew parts from inside the motor caseing or can it be pried without damage from the top? thanks"
  • fiantella
    fiantella Feb 08, 2014
    Remove side tanks. Remove casing (tower). No need to unscrew aything, just lift it. You swill see the 3 slots underneath the restart button. Blow it with a hair dryer for 5 minutes. The green light should turn on.
  • fiantella
    Cas Gabriel, Remember... This applies to Clairion DA-1030.
  • Cas Gabriel
    Cas Gabriel Feb 11, 2014
    fiantella mine is a Honeywell Quietcare HCM 6009 totally different from the Clairon and there is no reset button on this model.
  • mike Dec 30, 2016
    Check the thermo protector fuse at the bottom near the heating pad. The fuse must not be open circuit. If it is, replace it. You can order the fuse for $1 from eBay or Amazon. Good luck!
mike
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 99 Answers
  • Posted on Dec 30, 2016
 mike
Expert
Level 2:
New Friend:
Cheetah:
Answers
99
Questions
Helped
40197
Points
227
fiantella
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 06, 2014
fiantella
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1129
Points
"Take the humidistat out of the humidifier and look for the 3 slits below the restart button, take a hair dryer and send some warm air into those slits for 5 minutes. That usually recalibrates the humidifier."
Testimonial: "fiantella...can you please explain to me how to remove the humidstat. Do I have to unscrew parts from inside the motor caseing or can it be pried without damage from the top? thanks"
3 Related Answers
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Cool Mist Humidifier Filter Drying Out
Do you have tried to use without filter?
Anonymous
  • 478 Answers
  • Posted on Mar 12, 2009
SOURCE: Fan works, but no mist and water isn't going away
Turn on furnace and urn up humidistst to call for it. Tube from solenid to the filter should have water running if water is up to the valve and solinoid is opening . It should be warm to your touch., Using an ohm meter you can sheck the coil it shuold have continuity.
barceloj
  • 4 Answers
  • Posted on Feb 16, 2010
SOURCE: Honeywell HCM-305T Spits droplets rather than creating a mist.
this has nothing to do with any sort of nozzle as there isn't one on this device. As Skybum said, the "moat" overflows into the fan and then gets spit out as the fan turns. The device is wonderful at saturating floors but unfortunately not the air!
This is also not a consistent event. The humidifier will work for some time and then all of a sudden I wake up with a soaking wet floor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jason_ee8f979baffc115f
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
2answers
Humidifier not working
Mine is a SUL495 Filter Free unit and worked fine last year and the first couple of days recently, but I'm having the same issue, motor running , no mist, and trying to talk to someone @ in customer service today is a joke, I've cleaned everything but still no luck, I paid $40.00 for this unit in Jan. 2011 and have about two weeks until the warranty runs out, and the other wonderful thing is the nearest service center is about 50 miles away, I may wait until Monady to try to speak to someone, but I probably won't like the answers.
I have an HM 495, the past 4 days it has been working fine. Now there is no mist coming out and it seems to be spilling water out of the back of the base. What is the problem? I have not been using warm or...
When this happened to me, I took the tank into the bathroom to look at the bottom and then I tried to turn the knob and it wasn't all the way tight. After I tightened it, I put it back on the base and the mist started right away.
6helpful
2answers
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Family Care cold mist humidifer
cool mist humidifiers don't put out any mist. only the warm ones do. now if you put your hand over the area where it's coming out for about 2 minutes and take it away your hand should feel damp. almost clammy. if it feels like that the unit is working fine. so your not doing anything wrong. if you have any other concerns please let me know.
No mist
i would try cleaning the coils for the heat portion. if they are to scally that could be one reason why it's not making any mist. but if it looks pretty clean or if you have cleaned it and it's still not making any mist then it's something internal. now if your under warranty still that's a good thing. you can always call the manufacturer and they can replace theunit for you under warranty . if you have any other questions please let me know.
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
