Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Spray some WD-40 into the keyhole in the lock and wait a few minutes for that to set in. Then try to turn it again. If that doesn't work, the lock cylinder may not be inserted completely. Use the removal specific "key" that comes with Thule locks to pull the lock cylinder out, then reinsert the cylinder completely before removing the removal "key".
Hi, Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it. Thank you !!
If the lock tumbler has come completely out, look inside the hole, do you see a rectangular slot? if so put a screw driver flat tip in this slot and turn like a key it will open, then you should be able to access the lock mechanism from under the lid, may have to remove inner interior panel, the lock should be held in with a clip. Hope this helps, let me know.
if the phone is completely locked meaining it won't let you get into it or use it....the only way to resolve this issue is to have the manufacture "flash" the device. You will have to contact the manufacture's customer service line for this. Sorry
