The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
To freeze motion, you need either a fast shutter speed, or a fast flash in a dark environment. In less than bright light you may not be able to get a fast enough shutter speed to stop the action. Increasing the camera's sensitivity to light by increasing the ISO will help some.
You can blur the motion by using a slower shutter speed and a stable camera. Set a slow shutter speed and put the camera on a tripod or other stable surface, and you can get things like streaking car taillights and star trails. How slow a shutter speed depends on the speed of the subject.
You can pan with the subject. Move the camera with the subject, and keep it moving even while the display blanks out while taking the picture. This will keep the subject sharper while blurring the background to lend a sense of motion to the picture.
It's either to freeze motion if the subject is moving straight toward or away from you than if it's moving across your field of vision.
There seem to be a convergence problem affecting the television.
There are two ways you can fix the problem which are, you either replace the t-com board of the television, or you adjust the convergence from the menu of the television.
My best option is for you to replace the t-com board of your television and it will be in good condition once again.
I hate to say it but what this is is contamination under the actual LCD glass. This propblem starts during the manufacturing process and can rear its ugly head over time or after running at high temperatures for long periods of time. It can also appear as dark 'tiger' stripes. There is nothing that can be done to repair this. If you have an extended warranty, the mfg should exchange the panel for you. If your warranty is up, take photos and contact Toshiba online and try to get them to cover this regardless. This is a mfg defect.
The solution is documented on the Epson Support site if you can find it.
In printer properties (Printing Preferences), select the ICM button instead of Color Controls (the default) in the Color Management area. This is under the Advanced settnigs, not the Basic settings. I found out that leaving Color Controls selected and chosing a Gamma of 1.5 (the lowest they allow) also lightens up the printing.
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
