Western Digital WD Scorpio Blue WD2500BEVT - hard drive - 50 GB - SATA-300 SATA II Logo
A
Anonymous Posted on Feb 06, 2014
Western digital wd2500bevt slave jumper settings
Which jumper setting is for slave
Eric Andersen
Level 2:
Habit-Forming:
New Friend:
  • Expert 72 Answers
  • Posted on Feb 12, 2015
Eric Andersen
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
72
Questions
0
Helped
20910
Points
221
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
5 Related Answers
A
Anonymous
  • Posted on Mar 19, 2008
SOURCE: western digital hard drive
I have a WD800BB.
Jumper settings starting closest to the power connector.
CS for Cable Select
SL for Slave
MA for Master
The last two position are not marked.
Hope that helps.
Anonymous
  • 9 Answers
  • Posted on Mar 20, 2009
SOURCE: need master slave configuration
First set the jumper pin for master or slave configuration as provided in the cover of the hard disk.
Anonymous
  • 48 Answers
  • Posted on Apr 06, 2009
SOURCE: Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Anonymous
  • 111 Answers
  • Posted on Oct 30, 2009
SOURCE: Is there anyone who can tell me the jumper
http://www.wdc.com/en/library/eide/2579-001037.pdf
Try there it should help you out.
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Oct 27, 2010
SOURCE: I have a Western Digital
You can refer to this:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Jumper setting
SATA drives require no jumper settings
1helpful
What is the jumper setting for wd200bb 20gb hard drive for slave
Slave - Installing the new drive as the secondary drive:
If installing your new Western Digital hard drive as the secondary drive on the cable with
two IDE devices, move the jumper shunt on the drive to pins 3 and 4. If necessary,
configure the jumper on the other IDE device as Master.
How do set the jumpers on the HD to slave ? thanks
you can find the jumper settings printed on the top of western digital caviar hard drives
slave setting with the hard drive end jumpers facing you is 2nd from the right or 4th from the right
good luck
2answers
I need to know how to make model WD102AA-53ANA0 a slave. I am trying to move information on this hard drive.
Generally on a WD the center two pins is where the jumper goes for master with slave present. WD drives usually have it etched in the plastic SL, MA,CS.
2answers
Western Digital 80gb HDD Fails when installing OS
Try changing the jumper settings to make it the Master instead of the slave drive
2answers
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
I have found an oversight in your manual! regarding the jumper on wester digital drives. Do I put a jumper on both drives or just drive "D"
this is fixya, not western digital, but if you already have a drive fitted (C) this will be the master and the jumper set accordingly, if you have bought a second drive this will be the slave (D) or (E) dependant on drive letter allocation and the jumper set at slave
3helpful
3answers
Jumper settings
check this official web of western digital...
http://www.wdc.com/en/products/legacy/Legacy.asp?Model=WD400EB
Western digital hard drive
I have a WD800BB.
CS for Cable Select
SL for Slave
MA for Master
Hope that helps.
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
