Pioneer PL 500 Manual 2 Speed Direct Drive Turntable Vinyl Engine Cheers john. Stylus City
SOURCE: Pioneer PL-570 turntable (c.1973)
pioneer PL 570 tone arm drops and turntable shuts off, what gives?
SOURCE: PL-88FS with modern HDMI Receiver
Hi...
If the new receiver doesnt have a specific input in back labeled "phono" , You WILL need a preamp for the phono. Then plug the preamp into the AUX or other available input
SOURCE: pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
SOURCE: Where to get 12 volt power supply for Pioneer PL-203AZ Turntable?
+ is on center pin, and the current consumption is low, not more than 200mA. A 12V wall-wart will do fine.
SOURCE: 1970's vintage Pioneer PL-630 turntable w/ speed variation proble
THIS IS HOW!!
http://www.audiokarma.org/forums/showthread.php?t=92333
