Just dug out an old Juster computer speaker set (2 speakers, subwoofer and microphone) model 3D-FX3. I think it's over 10 years old. The mic works and the sound from the left speaker is great, but I get nothing from the right speaker. It's not the speaker because either speaker will work when plugged in the subwoofer's left port. Should I try to take the subwoofer apart and see if something is disconnected inside? Or should I just make do with one speaker?
Thanks so much for your help!
SOURCE: What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
SOURCE: Need the specs on adapter for JUSTer dc-691p speakers.....
Model: PPI-0930-UL
INPUT: AC 120V 60Hz
OUTPUT: DC 9V 300mA
Polarity: Neg.outside, Pos.inside
SOURCE: sound wont come out speakers
Not to sound like I am taking the pi**, but arae you sure you plugged into earphone/audio out????
Try using a pair of earphones you know work and if you get sound then the speakers could be faulty.
SOURCE: My microphone stopped working when i plugged it
go to control panel and open sound and audio codec in that go to audio change sound recording
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer
speaker system designed and sold by JBL. The system is made up of two
satellite speakers and an omni-directional subwoofer. The speaker system
connects directly to a computer's available sound card output jack or a
laptop's stereo output jack. Occasionally, problems can occur with the
sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable
connections. Ensure the satellite speakers are firmly connected to the
matching jacks on the back of the Creature's subwoofer. The
connections are color coded and, in addition, each speaker connector is
shaped differently to fit only into one jack. Ensure the output cable is
firmly connected to the subwoofer audio in jack and the computer's
audio-out jack. Ensure the power button on the back of the subwoofer is
pushed inward. If everything is connected properly, the green lights
on the underside of the satellite speakers will glow.If there is
still no sound, tap the right-hand side audio-increase button on the
right satellite speaker until sound is heard. Also ensure there is audio
playing from the computer. Double check the lower right-hand side of
the window's main screen and look for a speaker icon. If the icon has a
red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
