Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
have a tecnician take a look at cause it'' be hard to fix at home. something between the motor and the drum has loosened which may also cause short-circuit in the future, so just watch out...
I had the same problem with DENO, while we run the wash machine i press start button and step easier(try the start button and click buttons simultaneously until the code DOF) button until DOF code came, after everything went well. [email protected]
Indesit washing machine error code 3 (F03)
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows - NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
The wording of the error code explanation suggests the pressure switch
clicked on to register a water level, but when the water was drained
away it remained on instead of turning off. I would guess there could
be a blockage in the pressure system, or the pressure switch could be
faulty. Also, if the water didn't drain properly it would cause the
pressure switch to stay on too.
