You may download the manual at http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/4600_5600_en.pdf
SOURCE: Using Nikon Coolpix 4600 as a webcam
I'm using it through my TV card. It has a composite tv input.
But I'd like to find another solution.
SOURCE: Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
SOURCE: Replacing the battery door on a Nikon CoolPix 4600
Call 3104148107 This is the Nikon Parts line, be warned it will probably take as long as 30-45 minutes of old time to get to a person.
Once you can get to a person, give them the camera model and describe the problem. They just sold me a replacement battery door for $9.95 + $6 dollars shipping and handling.
The rep was so nice he even printed out the device design blow up, and the relevant section of the manual, so I could see the step by step with out having to purchase the full blown repair manual, which runs $83.
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
