Dewalt 18 Volt Compact Drill Kit Logo
A
Anonymous Posted on Feb 05, 2014
Dewalt battery charger flashing fast not chargeing
Battery charger flashing fast not chargeing
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 07, 2008
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Anonymous
  • 2176 Answers
  • Posted on Feb 19, 2009
SOURCE: I have a 12v dewalt drill driver DW907K-2 haven't
It flashes slowly until battery charged. The flash in a rapid motion means that the battery is bad and needs replaced.
Anonymous
  • 137 Answers
  • Posted on Apr 13, 2009
SOURCE: Recharging a Dewalt battery Yes or No
NO!
Mike Squire
  • 420 Answers
  • Posted on Jun 18, 2010
SOURCE: CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on May 18, 2011
SOURCE: Cannot recharge 18v battery, place
You will need to replace the battery it is defective.
My Dewalt battery charger DE9116-XE flash's fast after slowly flashing at the start. The explanation on the charger is if this happens to replace pack, but this is a new battery I just bought It.
some batteries are bad from factory, you should exchange it for another and try again. Make sure the battery voltage and type (ie. lithium, Nickel Cadmium,etc.) match the charger. If not, you can buy most replacement batteries for older models on the internet. If a second battery doesn't work - it's the charger .
If this is a newer purchase, my newer Milwaukee flashes slow for the first two beats and then quickly while it reads the battery type and then shifts to the slow flashing charge light after it determines the type. this is because it is a smart-charger and can charge different types of batteries
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
2answers
Light flashes fast on dewalt 0245
I believe the battery can no longer be charged.
Aug 31, 2014 • Drills
Dewalt 30 Minute Fast Charger does it work in uk 230v
Some battery can not be charged by fast charger, because this can damage the battery. You can think to replace it to a new charger, a 7.2V 9.6V 12V 14.4V 18V NI-CD NI-MH BATTERY charger for Dewalt
Jun 22, 2014 • Drills
My DE9116 battery charger keeps flashing very fast and not charging, any suggestons? I have changed the fuse!
IF is doing that without battery on it maybe charger is bad but if flashing that way when you put the battery could be the battery hope this helps!
The charger flash red very fast with battery charging and the battery will not recharge
This means there is a "pack condition" and the charger believes the battery is bad.
I purchased a new DeWalt DW1916 Battery charger and when I install the battery for charging, the red light on the charger blinks on and off and after an hour the battery was still discarged.
If you look on the charger there should be a flashing codes should be explained depending on the type of flashes. Very fast flashes, means bad battery.
Oct 01, 2010 • Garden
7helpful
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
2helpful
Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
