Error code c-0202.Tray 1 problem
Open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
SOURCE: adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
SOURCE: error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
SOURCE: on the bizhub C550 an error code C0204..... won't
Two things 1) check to see if there is paper in the back of the of the tray where it meets the back wall (that would prevent the paper tray from rising. 2) there is an upper limit sensor on the paper feed (thats where the rollers are) so check to see if any bits of paper blocking the sensors. If you find it, reset the machine and it will see the tray.
SOURCE: Error code c0202. What is
Most likely there is paper stuck in the very back behind one of the trays. Take both trays out and see if there is any paper jammed (could be a small piece). Put trays back in but leave them open, turn off the printer, unplug it, wait 5 minutes, plug it back in, turn it back on and push in the trays.
