Question about Panasonic PV-C2010 20 in. TV/VCR Combo
I9 have a 20" panasonic tv when it is plugged in it doesnt turn on
When its plugged in initially  and when try to turn on it turns on and right away it turns off than each time after pulling the plug from recepitcal when i plug back it would turn on once and right away turn off and after repeating few times it stays on sometimes. the power switch will work only after unplugging. thanks
Sounds like a power supply problem.... would start there...
Posted on Jul 25, 2008
SOURCE:
Panasonic Viera TH-37PX60U not turning on. Six blinking lights.
Try below and if still doesnt work itsbetter to call a repairman .
Here is the simple 5 step process we follow when this happens to our plasma tv. It works most of the time.
1) Completely unplug EVERYTHING connected to the tv, including HDMI cables
2) Press and hold the power button on the tv for 10 seconds
3) Plug power cord ONLY back in to TV
4) Turn tv on.
5) Plug in all other cables at this time.
It is helpful to use a good surge protector with this tv. It still goes out occasionally but not as much.
If the process does not work, wait longer (like an hour) after unplugging everything
Jun 04, 2018 | Panasonic Televison & Video
Problem with lamp turning on
maybe try turning off at wall rebooting device can harm the computer if you turn off both you may turn off modem box thingie
Nov 21, 2013 | Panasonic PT-50LC13 50" Rear Projection...
The tv turns on, then turns off right away
You have a problem in the High Voltage section of your TV. I would call the nearest tech.
Aug 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Camera turns off by itself after taking a picture
A friend of mine had the same prob after putting in brand new batteries, it was i bit wierd but i tried some different batteries and it started working , try some new batteries. hope this helps.
Feb 28, 2009 | Panasonic Cameras
Shadow Box in top Right Corner with number 2 in it won't turn off
I need full details to assist you.Please let me know what is your cable box company?Which HDMI input from the TV?
Where do you set your cable box?Above?Below?Away?
Solutiondoct
Oct 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV DOESNT TURN ON ,I SWITCH PLUGS ,I TRIED TO TURN THE TV ON FROM THE TELEVISION ,CAN YOU PLEASE HELP.
Possible blown fuse or worse. If you attempt to change the fuse use the same amps that is in it.
Mar 09, 2008 | Panasonic CT-36SX12 36" TV
Panasonic PV-C2010 20 in. TV/VCR Combo Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
