Question about Johannes Wallroth Multi-Timer Ultimate
MULTI TIMER ULTIMATE - Johannes Wallroth Multi-Timer Ultimate
Have a 10 year old Whirlpool Ultimate Care II top loading clothes washing machine. In the "Delicate" cycle, it stops after agitating sometimes and will not kick into the spin empty part of the...
Yes it is a timer issue, and yes the whole timer will need to be replaced. If you are handy it is not very hard. You can order the timer from marcone.com with your model # and it will show you a parts breakdown so you can see hoe to replace it easier
Nov 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer wont fill model number wtw57esvwo
u mean wont fill with water first thing to check is your water valve fromthe inside take a multi meter and make sure you have power going to and fromthe vavle remove the leads that plug into the vale and test eachone that they have power if it is not you watervalve the next place to check would be your timer 90 percent of the time it is your water valve that goes bad you can order either part from marone appliance parts and they will send it directly to your door hope this helps
Jul 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care will not stop spinning
I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
Hope this helps _MJ_
Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Dryer timer knob
The timer cam is not aligning the internal switches. Replacing it is the only fix.
Eric
Sep 17, 2009 | Kenmore 62602 Electric Dryer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care ll washer
on the back of the timer is a black plastic tab, you have to pull out on this tab in order to remove the knob. in other words you have to take apart the control panel to get to the timer just to take off the knob. :I
Jun 23, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II washer
If it will perform all of the functions if you turn your timer knob manually, I would open the console and check for any loose connections, although from your description your timer motor has gone bad (only availible as the whole timer) It can be purchased from online from the manufacture or from a local parts store.
Jun 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Computers & Internet Logo
14 people viewed this question
Top Johannes Wallroth Computers & Internet Experts
Alun Cox
k24674
Are you a Johannes Wallroth Computer and Internet Expert? Answer questions, earn points and help others
