Home Logo
Robert Numa Posted on Feb 05, 2014
Leaking kitchen tap
Kitchen keeps leaking water even when tap is closed tight
clarke samuel
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 06, 2014
clarke samuel
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
1674
Points
30
It is very easy to stop it just make sure you lock the tap and loose the tap head from the pipe then you get what they call white thread for taps just rap the thread round the tap and you just fix it back
3 Related Answers
Rich Carothers
  • 65 Answers
  • Posted on Jan 26, 2011
SOURCE: jetted tub is on 2nd
First find access to tub,by code there needs to be access to pump motor,either built into wall or various tubs front skirt is removeable.Fill tub and run to visibly see leak,sounds like bearing assembly gaskets are leaking on pump,could possibly be a jet connection,but if it only does while running its the pump or motor assembly.Hope that helps,in the future make sure water is always above suction intakes or can lead to premature burnout of pump
Anonymous
  • 2006 Answers
  • Posted on Aug 16, 2011
SOURCE: need to change a washer
You will need to shut the water line off and disconnect from the faucet. Then you will need to unscrew the nut holding the faucet in place. Take the faucet out and then you will be able to disassemble the faucet and replace the washer. Newer faucets use a cartridge with the washer built in.
Anonymous
  • 51 Answers
  • Posted on Dec 18, 2012
SOURCE: Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Flick mix kitchen sink leaking under handle of left/hot, right/cold. Centering between hot and cold lessen the leak. This is happening when no water is being used.
indicates that the center shaft seal is leaking
It could be leaking from under the insert if it is hard to move the lever sideways
generally the ceramic insert is non repairable so it may be a new insert or tap assembly
Aug 11, 2018 • Plumbing
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
I have a kitchen faucet that is leaking at the base where the faucet connects to the base. It leaks all the time. Do I need to replace the O rings in the stem of the faucet? Or do I need to replace all...
hi! if tightening the knob(s), (or if you apply pressure on the knob of the faucet,for the models with no thread for open/close), modify the amount of water leaking ,you need to replace the seats in the faucet. if not ,just replacing the o rings should fix your problem.
Lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Aug 12, 2010 • Home
Single lever kitchen faucet,seal broken
To address the leaking problem fast, you may replace
the whole set.
1. Shut off the main water valve.
2. Take the leaking kitchen faucet off.
3. Replace the defective kitchen faucet.
4. After replacement, open the main water valve.
Of course, you could have repaired it. That is assuming that you could easily find the right seal.
Besides there is no guarantee that the location where
the seal will be placed is still not wornout.
Nov 29, 2009 • Plumbing
I just replaced the cartridge, spacer, check valves and oring that sits on top of manifold and water still leaks within body of faucet. any suggestions?
SOUNDS LIKE A LOOSE FITTING , INSPECT UNDER THE TAPS FOR ANY LOOSE FITTINGS AND TIGHTING THEM UP WITH A AJUSTABLE SPANNER UNTILL WATER STOPS LEAKING.
1helpful
Leaking Kitchen Tap
yes your right it's the seal inside and it can be replaced you should shut the water off after all why make a mess when you don't have to. however I'm not familiar with this typ of faucet. you more than likely be able to get help from your local area hardware store when you purchase your gasket for replacement.
Sep 02, 2008 • Plumbing
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
