The knob that turns the settings dial has broken and sheered off the peg it attaches to so I can't even turn it to express. Currently stuck on starch as I was turning it to empty/spin cycle. Is this easy to fix or does it involve having to replace a whole unit/circuit board
SOURCE: Sears Kenmore Elite washing Machine.
probably new timer part inside timer that locks shaft when pushed inis not grabbing and locking
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
SOURCE: Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
