Olympus Stylus 700 / 700 Digital Camera Logo
A
Anonymous Posted on Feb 05, 2014
02 ran 5 power wont - Olympus Stylus 700 / 700 Digital Camera
Pulled 02 gmc in garage ran fine now it turns over and wont start any help?
sounds like fuel pump check for power an pump is working should hear humm from gas tank as key is switched on
02 yamaha vstar 1100, ran fine. started it the
Sounds like it may be drawing air around the intake somewhere. Let it idle and spray around carefully with wd-40 until it speeds up. This will reveal the leak.
02 2.2 l ran fine ran out of gas wont start replaced fuel filter still wont start
Sometimes If a car runs out of fuel the fuel system needs to be bled to get rid of air locks.
My 2003 yukon won't start.while idling car ran out of gas
you are either lacking SPARK or FUEL. You put 5 gal in the tank, but is the FUEL PUMP working ? The lights and radio operating only indicate ther is power in the battery.. Hope this helps.
1helpful
Engine light wont go off.
The catalitic converter is a mechanical device , it simply converts harmful emissions into water/vapour. The 02 sensor if faulty would put the engine management light on. If the 02 sensor has been faulty for sometime it could tell the ECU to supply the wrong amount of fuel to the engine which in turn would eventually damage the catalitic convertor. So you may have to change both in the end, but first I would check out the 02 sensor and replace if required.
2answers
2005 Chevrolet Cavalier, No power
check air intake hose first, including MAF sensor (if dirty must clean) , then check for all other hoses for leaks and last but not least check air filter.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
