Nortel Nertworks Meridian M3904 Charcoal Display Phone NTMN34GA70 Logo
A
Anonymous Posted on Feb 05, 2014
Nortel m3904 blank screen - Nortel Nertworks Meridian M3904 Charcoal Display Phone NTMN34GA70
2 Related Answers
Anonymous
  • 58 Answers
  • Posted on Jun 23, 2009
SOURCE: how to transfer a call on Nortel Networks M3904
Use the Transfer feature to redirect a call to the appropriate person.
To use the Transfer feature to direct a call to a third party:
To return to the original call, if the transfer is incomplete:
1. Press the Transfer soft key. The other
party is on hold and a dial tone sounds.
The LCD indicator light flashes steadily.
2. Dial the DN to which the call is to be
transferred or use Personal Directory,
Redial List
, or Callers List to select a
number to dial.
3. When that number rings or a person
answers, press the Transfer soft key to
connect the calling party.
If the person called is not available,
press the line (DN) key (next to the LCD
indicator) to reconnect to the original
call.
Anonymous
  • Posted on Jul 26, 2012
SOURCE: nortel phone m3904 won't forward to an outside line
First, you need to call your telephone company and ask them to enable this service. There may be a fee which is why it is not a standard service.
I have a Nortel Networks M3904. I need to unlock voicemail because I can't remember my new password I set. We do not have the Admin phone to go to. Can you tell me what I need to do?
might be best if you reset password. go to your email web site and log in. email address fine, then look for small question forgotten password.
complete with your email address, if recorded with email website it will send you a link or offer to alter change password. if lucky then remember to save password to pc memory. you can then look up in settings passwords in fact try that first go to settings and general then passwords
if logged you should get code to open if you haven't altered try 0000 bevlucky will let you in then sift through other passwords to find your. then edit change AND REMEMBER. GOODLUCK.
How do I set up a voice mail with a Nortel M3904?
This is dependent on you being able to access your voicemail mailbox (a mailbox has been setup for you by the administrator and you know the codes to login to your mailbox). Go to your voicemail which should be:
  1. press the message key.
  2. Enter your mailbox number, then press #
  3. Enter your password, then press #. (if you don't know this then you will have to contact the administrator for the telephone system)
When logged into this:
  1. press 82.
  2. Press 1 for external greeting, 2 for internal greeting, 3 for temporary greeting, or 9 for Personal Verification (spoken name)
  3. Press 5 to record then wait for tone.
  4. Press # to end recording
  5. Press 2 to listen to the greeting
  6. Press 76 then 5 to delete the greeting and re-record it.
  7. Press 4 to return to your messages.
Display is blank
Phones I work on have a ribbon cable going from display window to main body, sometimes get knocked around and ribbon cable dislodges. Just have to reconnect cable, inside the phone.
How do I change the number dialed for an outside line on a Meridian M3904
This is a PBX programming issue and mostly system wide, you must call in a tech to change this type of programming.
2answers
Nortel phone m3904 won't forward to an outside line
The DN may not be configured to allow forwarding to an outside line for security reasons. I think the default is 4 digits. You will need to talk to whomever programs your switch and ask them to allow this feature.
2helpful
How to transfer a call on Nortel Networks M3904
Redial List
number to dial.
call.
Nortel Meridian phone lcd blank on one side
Shounds like the screen has shifted and is no longer making contact with the membrane.
Unfortunatly theres not too much you can do with it short of sending it in for repair.
Top Nortel Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
