TruTech PLV16320 Television Logo
Posted on Oct 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen shuts down after 15 minutes
Screen goesblank after fiftenn minutes of picture. Cannot restore. Several hoursafter unplugging and replugging, redlight comes on and sometimes screen shows for several minutes before going blank. Remote cannot turn screen to standby
  • Anonymous Nov 20, 2007
    I have exactly the same problem. I returned the Television and the replacement does the same thing
Anonymous
Level 2:
Champion:
  • Expert 367 Answers
  • Posted on Jun 17, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
367
Questions
10
Helped
54679
Points
448
It could be sleep timer,but I would say it is a capacitor problem in the power supply.Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
2answers
2helpful
2answers
The TV is turned on and has only sound with backlight.The problem is it takes several times turn on and off to make the picture come up. When it came up picture has a lot of horizon lines like static
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1helpful
Random shutdown
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
2answers
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
3answers
Pilot
tell it to go in normal mode just say sthat when u boot up cuse u shut down inproperley ok might wann buy new video card make sure it pluged in to a hi end power strip ok
Top TruTech Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
